Decarb tell me more
Decarb tell me more
what is it you are trying to do how often is it done is there signs to look for after you do this how do you know if its done right :confused: :skep:
Re: Decarb tell me more (kewlpapaw)
I havaen't done it yet, but here is a link that someone else posted. It gets discussed here once in a while. http://www.corvetteforum.cc/techtips...=119&TopicID=5
Cruise-In II Veteran
Hi there,
Well, decarb is usually a last resort to excessive cold start noise, or even worse, engine detonation.
Usually, 12345515 Fuel system additive once every six months from a new purchase, will usually take care of all carbon build up issues on daily driven cars.
If for some reason, you drive short trips, without any extended long driving, then the service interval will increase, because carbon buildup is not burned off.
Allthebest, c4c5 :banghead:
Re: Decarb tell me more (c4c5specialist)
Hi there,
Re: Decarb tell me more (white93)
I took some of the cleaner and placed it in a cup and put some carbed up valves in it. After 24 hours of soaking, NONE of the carbon would come off the valves and there was little black markings on the WHITE towel I wiped the valves with. I then heated a valve and then poured the GM TEC onto it and the carbon started to come off within 15 minutes. The cold procedure doesn't work and the only part of it that might be helping is the heated test drive part. It is best to follow GM's insructions on the can. I poured it into the car while running at full temperature. I see little advantage of waiting 6-12 hours with the car cold before blowing out the carbon as most people on the forum have suggested. Heat seems to be one of the most important elements to the cleaning.
Re: Decarb tell me more (SpinMonster)
it's easier to add water ( slowly ) thru the brake booster vac. line while the engine is running.
Works great without the getting messy. :yesnod:
I just did this two weeks ago and the results were quite nice.
Initial post about it: http://forums.corvetteforum.com/zerothread?id=561767
Results post: http://forums.corvetteforum.com/zerothread?id=564165
GREAT post by RskyBns with pics on how to do it: http://forums.corvetteforum.com/zerothread?id=501685
Patrick :cheers:
Patrick :cheers:
Re: Decarb tell me more (Patman36)
Patrick :cheers:
Patrick :cheers:
Great job on the decarb! :cheers: Another successful one done! :thumbs:
I like your results, perfect. BTW, what did you decide about your plugs?
Andrew
[Modified by RskyBns, 9:18 AM 5/27/2003]
Re: Decarb tell me more (RskyBns)
Andrew
Andrew
Patrick :cheers:
