What Fuse Only sees Power when the Fog Lights are on?
Re: What Fuse Only sees Power when the Fog Lights are on? (chuckster)
Chuckster,
Did you notice any real gains with your powerloader and MAFT. How much did you have to change your MAFT setting after install (%)? I'm still lookiing at going with a Predator as soon as he comes out for one on a 98 6 speed. What do you think? :steering:
Re: What Fuse Only sees Power when the Fog Lights are on? (borba)
If you want to get rid of the annoying daytime running lights, remove fuse #2 under the hood it is a 15amp one. look at the diagram under the cover.
Chuckster,
Long Time...
I don't have the MAFT anymore. I now have LS1-Edit... But I think I felt a small gain..
Predator is a great tool for those who don't want to dive feet first into uncharted waters.. :D
If you are aiming for not DRL's, IM or E-Mail me
and I can tell you how to maintain ALL your other
functions (approach etc) and do way with the DRL's.
Barry
:cheers: :cheers: :cheers: :cheers:
Barry
Re: What Fuse Only sees Power when the Fog Lights are on? (rbartick)
Yep, that is the one I found!! Thanks for the nice schematic.. :cool:
I tried looking in the fuse block next to the battery and found it Saturday night. It's perfect for powering my .....
Ahem.... NEONs..The Transformer draws only 450ma
I tried it out.. When I hit the keyfob to unlock the doors...This also lights the fogs and just like I wanted.....the Neons at the same time. :cool:
