Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-17-2003, 09:07 PM   #1
JACSZ06
CF Senior Member
Default Water/methanol injection?
Has anyone had any experience with water/methanol injection? If so what are the benefits, drawbacks, horsepower gains and whatever other information anyone might have? Thanks in advance. :thumbs:
JACSZ06 is offline   Reply With Quote
Old 04-18-2003, 10:35 AM   #2
rgregory
CF Senior Member
rgregory's Avatar
Default Re: Water/methanol injection? (JACSZ06)
About methanol, never used water injection...
First of all the drawbacks: it would take major modificatoins to the C5 to make it Methanol compatible. Methanol eats through normal fuel lines, it eats through aluminum. Only a few cars on the market have fuel pumps compatible with methanol (seen those flex fuel badges on the back of some Fords? those are compatible have used them out of I think it was a Taurus) You also have to way richen he system as it takes alot of methanol compared to gas (almost double).
The advantages of methanol is its heat of vaporization. When it is sprayed out of the injectors it gets cold. We used M85 (15 percent gasoline 85 percent methanol which is safer because you can see it burn unlike pure methanol) at school in our turbo charged race cars. With M85 there was no need for a intercooler because the methanol cooled the incoming charge. Also methanol likes high compression. We were running 7-9psi of boost on an 11:1 compression engine.
However my last year of school we went the non-turbo charged route and determined there was no advantage to methanol if we were not boosting and used gas.
[Modified by rgregory, 9:35 AM 4/18/2003]
rgregory is offline   Reply With Quote
Old 04-18-2003, 11:12 AM   #3
C5-VERT
CF Senior Member
Cruise-In IV Veteran
C5-VERT's Avatar
Default Re: Water/methanol injection? (rgregory)
:withstupid: You WOULD only need it if you were boosting enough to create some detonation. Methanol/Water just cools the cylinder down by spraying a fine mist into the intake track. Intercoolers are pretty good now + keeping the methanol/water filled up make them almost retired.
C5-VERT is offline   Reply With Quote
Old 04-18-2003, 04:18 PM   #4
aaaa
CF Senior Member
Default Re: Water/methanol injection? (C5-VERT)
:iagree:
aaaa is offline   Reply With Quote
Old 04-18-2003, 06:58 PM   #5
JACSZ06
CF Senior Member
Default Re: Water/methanol injection? (aaaa)
Are there any advantages in putting it on a normally aspirated engine? Let's say you have a supercharged vehicle with an intercooler. Would it be possible to use the water/methanol injection, in fine mist form, to create lower intake temperatures even with an intercooler? Has anyone tried this setup on any type of vehicle (supercharged or NA)?
Old 04-19-2003, 05:21 AM   #6
twincam47
CF Senior Member
twincam47's Avatar
We used to use them years ago. It was ran thru the PCV system.
All it was was a plastic cannister. 2 parts water, 1 part methanol.
the cannister had a small hose routed from the cover to the bottom inside allowing air to come into the cannister and make it bubble and another hose on the top allowing the vapors to be pulled off by way of a tee in the PCV line.
.......The vaccum pulled by the pcv line would cause incoming air and bubbling and allow the resulting vapors to be pulled up the pcv line.
....these were kits sold in the 70's.......They allowed use of lower octane gas and kept the plugs cleaner......
other benefits........I just don't know...... :flag
twincam47 is offline   Reply With Quote
Reload this Page Water/methanol injection?
Tags
c5, corvette, injection, magnuson, methanol, running, turbo
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
For Sale Team Zr1 Water Alky Injection Kit JohnFather C5 Parts for Sale/Wanted 10 04-25-2005 08:45 AM
High pressure Water/Methanol Injection arkansascorvette C5 Forced Induction/Nitrous 98 12-08-2004 11:00 PM
Water/Methanol injection and Magnuson S/C arkansascorvette C5 Forced Induction/Nitrous 10 12-01-2004 04:09 PM
Anyone using Water/Methanol Injection on a boosted C5? Rob0451 C5 Forced Induction/Nitrous 12 12-09-2003 03:00 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
