How about 1. Tech - OEM & non-performance, 2. Tech - Performance??
CF Co-Founder
I'm suggesting these two categories based on the feedback from the other thread on the subject. At first I was thinking that we should break it down into more sub-groups but you've convinced me otherwise.
I want to keep it simple while at the same time allowing the performance based topics to thrive. I think that we have had fewer of the hardcore performance threads over the last year because they get lost in the OEM and generic tech questions. Seperating the OEM type questions into another section should help quite a bit.
The other C5 sections would stay the same. I find the FI/Nitrous and Scan/Tune sections to be very helpful as distinct sections. Scan/Tune gets about 18 posts per day since it was formed and FI has averaged 55 posts per day since it was opened. That makes them both pretty useful resources of concentrated knowledge. It makes sense to me to leave them as they are.
Here is the proposal based on the feedback:
Split the C5 Tech section into these two categories to keep it simple:
Tech - OEM & Non-Performance
Tech - Performance
Existing sections:
Tech - Scan & Tune
Tech - FI & Nitrous
Z06
General
For Sale
Parts
I know some won't want the sections split at all, but it makes a lot of sense to me. If we don't do something along these lines we will slowly lose a place where you can discuss serious tech subjects in depth.
We can make these changes easily. We are also looking at a few more things to help in the future. One of the big ones is the ability to move a thread to another section and leave a pointer behind to find the new location. This is a longer term feature but it will help a lot when it is available.
Feedback?
Tech - Performance
Existing sections:
Tech - Scan & Tune
Tech - FI & Nitrous
Z06
General
For Sale
Parts
Feedback?
CF Co-Founder
Re: How about 1. Tech - OEM & non-performance, 2. Tech - Performance?? (Troy Roberts)
We will need to get feedback on the cutoff lines as to where topics should go. Some will always be borderline, but we need to setup some guidelines to make it as clear as possible.
Tech - Performance
Tech - Performance
There’re no easy way to distinguish “Hard-core” from “non-hard core” tech :nonod: and a lot of topics from either would often be relevant for a common interest
However, Performance vs.Non-performance is perfect IMO. :thumbs:
If somebody is interested in info on how to make his car faster Non-performance tech topics like “How to install a shifter” etc totally don’t apply.
Troy:
Whatever definations or guide lines you use, there will always be some confussion about which section to use. Even the technical/general definations are misused by some. The Titles suggested by Mike are good ones, however, to me they are too specific, and you could start adding even more "Technical" categories such as Aerodynamics and Electornics and possibly more.
The categories of OEM-nonperformance and Performance should be easily identified and used by Forum Members. :cool:
Re: How about 1. Tech - OEM & non-performance, 2. Tech - Performance?? (johnC5)
Tech - Performance
Simple is good.
Tech - Performance
Simple is good.
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Re: How about 1. Tech - OEM & non-performance, 2. Tech - Performance?? (99Z51R)
TROY:
Sounds like a great solution and game plan. Thanks for keeping an open mind to this from when i first posted about it about 5 weeks ago! :cheers:
MTI 427 Roadster
MTI 427 Roadster
Get Some!
Sounds good and easy to me. Here are some things your guidelines should address where OEM and performance blur. Any one putting on aftermarket or worked heads would know to post in performance, but someone with a 97 who is adding Z06 (i.e. OEM) heads, cam, suspension might be confused where to post questions, I think they should go to the performance side. But some thing less complicated like Z06 rear brake ducts on a 97 goes to the OEM side. Swapping an out your LS1 for a 6 might all be OEM but because it is complicated that should go to the performance side.
Now the PCV mod is all aftermarket, but it is very simple and doesn't add HP so it goes in the non-performance, and freaking Zaino threads stay in the Car Care side :yesnod:
Hope that helps.
Hope that helps.
Troy - you know how I feel. There are already too many C5 sections. I'm not sure what is broke here. You say that there have been less hard core performance threads.
I think two reasons. One, the C5 is becoming pretty mature. Two, everytime there is the least disagreement on a thread, ya'll shut it down because you decide there is "nothing else to add to this thread". I've seen that many times.
It's your forum, you can do what you want. But it seems to me that there were an awful lot of posts on your other questionaire that said they did not want to add more sections (even though you told everyone not to do that).
I for one am going to miss an awful lot of useful information and knowledge because I don't want to have to go into 6 or 7 sections. All that just because a few guys get irritated if they have to look at some thread titles that they don't want to see.
Troy,
I patiently waited to give you my opinion on the first poll because you said you specifically didn't want yes/no answers.
Personally, I don't see how the C5 Tech section is going to benefit from splitting it again. Maybe the performance topics get buried, but if I spend my time in the OEM section to maintain my Vette I'll miss out on new things that pop up in the performance section.
Also, I guess I just don't see what problem you're trying to fix. I think the OEM section will just turn into a "C5 General, Part Deux" section. C5 General already has several instances of OEM type tech questions ("what do you think of the non pop-up headlights?").
Hey, it's your forum; we don't pay a dime. I'm not going to go away if a split happens; but I just don't think it'll truly improve your product.
Have a good one,
Mike
Have a good one,
Mike
I like the idea of OEM versus a pure aftermarket performance Tech section. The idea of moderators moving inappropriate posts to the other section if misposted and leaving a forwarding arrow would be a great improvement. :cheers: :thumbs:
Re: How about 1. Tech - OEM & non-performance, 2. Tech - Performance?? (Dave00C5)
Nice work. :cool: It's simple, so it doesn't separate us too much and "water-down" the forum, but yet it leaves minimal grey grey area as to where you should post. I think it'll work quite well.
Having said that, I think one more division IS necessary. The audio/electronics in the general section really should be divided by model, as the wiring between generations is extremely heterogenous. This would also get the audio/electronics section more traffic if it was within the C3-C4-C5 areas.
I like the OEM& NON-Performance and Performance split. Easy to understand. I think that a lot of post get burried, big head and valve questions in between questions about squeaky brakes and dash lights not working makes it harder to find what you are looking for. Not that either ? is more important then the other, but they are seperate types of issues.
Bill
Bill
1 Post
Tech - Performance
Simple is good.
:iagree: :iagree:
Tech - Performance
Simple is good.
:iagree: :iagree:
Re: How about 1. Tech - OEM & non-performance, 2. Tech - Performance?? (vstella)
I like Troy's proposal:
Tech - Performance
Tech - Performance
Re: How about 1. Tech - OEM & non-performance, 2. Tech - Performance?? (Ross78)
Troy--
I think your proposal is good, and the break point between Perf and OEM/Non-perf should be obvious, but...........
......then I realized you intend to keep General. Now, I'm concerned about about the blur between OEM and General, as VetteDrmr mentioned in his post, above.
So, should the OEM title be more specific, such as "Tech - non performance repair and maintenance" to further define the section? And maybe "General" needs a word or two to define that content, too.
Otherwise, your plan is a good one, as it's simple, adds only one new section, and basically keeps the rest of the C5 sections as they are.
CF Co-Founder
Re: How about 1. Tech - OEM & non-performance, 2. Tech - Performance?? (Tracy)
You're right. We need to come up with a good definition for the General section. I think it makes sense to have it for topics like BSMs or No BSMs ;). There are going to be C5 related discussions that don't fit into a tech category. We just need to make sure we draw a line between General and OEM.
