Bar none, what is the best clutch setup for a stroker?
Topic says it all. Looking to install a bulletproof clutch with my 427. Presently leaning towrd the Star Spec brand.
Please add any relevant info, i.e., price, delivery, vendor, chatter, etc..
thanks
thanks
Re: Bar none, what is the best clutch setup for a stroker? ('97 C5)
Do a search on the RAM clutches as they are good up to the 750RWHP mark from what I can remember.. :cheers:
Now, I'm *only* making a measely 400rwhp, but I just got a mcleod dual disk installed and I am loving it. I was previously running the stock z06 clutch, and to honest, I don't think it ever harnessed all of the power I was making after my cam install.
The car feels much faster now, and I know its not all coming from that 3"xpipe I had installed along with the clutch. The mcleod is obviously transmitting every last bit of power possible. Thankfully, it daily drives just fine, especially after all the horror stories I had heard of runaway clutch engagements at low speed. Mine does engage a little higher in the pedal range than stock, but it only takes a day or so of driving to relearn. :cheers:
Re: Bar none, what is the best clutch setup for a stroker? (BLU-BY-U)
BLU-BY-U, would it be possible for you to adjust the engagement point, since you presumedly have an adjustable master cylinder?
Former Vendor
Re: Bar none, what is the best clutch setup for a stroker? (CJS)
CJS,
When I first got the McCleod dual disk installed, the engagement point was still little too high even with the master cylinder adjusted all the way.
But this engagement point will drop down lower after you put a few hundred miles on the clutch. :)
:cheers:
-Tuan
:cheers:
-Tuan
CJS, I think Tuan covered it.
MTI did the install and said it would be a little higher, but would "settle" in over time. I've only got 150 miles on it, so it's still really new. But I'm working on it... :D
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Re: Bar none, what is the best clutch setup for a stroker? (NoMercy)
Our G2 Heavy Duty clutch is 20lbs lighter than stock and good to 800HP.
:crazy:
:crazy:
