What happens if you accidentally pour in Coolant instead of Oil into motor?
Old 02-13-2003, 01:49 AM
Hirohawa
Hirohawa's Avatar
Default What happens if you accidentally pour in Coolant instead of Oil into motor?
If you were going to top off the oil and you accidentally poured in a splash of coolant would you harm the engine? Not a lot of coolant just an ounce or two.
Old 02-13-2003, 01:52 AM
CP
CP's Avatar
Received 1,125 Likes on 562 Posts
Default Re: What happens if you accidentally pour in Coolant instead of Oil into motor? (Hirohawa)
Don't know, but I would change the oil IMMEDIATELY!
Old 02-13-2003, 02:52 AM
Sam Lin
Sam Lin's Avatar
Won't hurt it unless you run it (blown head gaskets mix coolant and oil all the time) - change the oil before running it.
Sam
Old 02-13-2003, 06:32 AM
NassBlue
NassBlue's Avatar
Default Re: What happens if you accidentally pour in Coolant instead of Oil into motor? (CP)
:iagree:
Old 02-13-2003, 07:46 AM
Killrwheels
Killrwheels's Avatar
Default Re: What happens if you accidentally pour in Coolant instead of Oil into motor? (NassBlue)
If you are **** about it, like most of us, you could have it towed to the dealer and have the engine cleaned with the that Bosch process. Kinda forces all the contaminants out and all the old oil, but it is usually only reserved for the older models with sludge buildup.
Old 02-13-2003, 08:28 AM
Dave00C5
Dave00C5's Avatar
If it was just a splash it shouldn't hurt it untill you get the oil changed. Anymore than that say like a cup or so I'd change the oil immediately before running it! :steering:
Old 02-13-2003, 08:44 AM
vetterdstr
vetterdstr's Avatar
CA Events Coordinator
You have contaminated your oil and it needs to be changed right away... do not drive your car in the meantime.
vetterdstr :cheers:
Old 02-13-2003, 08:48 AM
MTWallet
MTWallet's Avatar
Default Re: What happens if you accidentally pour in Coolant instead of Oil into motor? (vetterdstr)
Don't start the car, just change the oil. If you have already started it, just change it right away. All of the coolant is sitting on top of the oil in the pan and should come out when it is drained. Anything left behind will go away after the oil gets hot.
Old 02-13-2003, 08:55 AM
George Cooper
George Cooper's Avatar
Default Re: What happens if you accidentally pour in Coolant instead of Oil into motor? (MTWallet)
Wow! This is exactly the sort of thing I, as a professional clod, might do. You have made my day!
Old 02-13-2003, 09:13 AM
C5 StockSwap
C5 StockSwap's Avatar
Cruise-In V Veteran
St. Jude Contributor
Default Re: What happens if you accidentally pour in Coolant instead of Oil into motor? (George Cooper)
:skep:
Old 02-13-2003, 09:25 AM
IMQUIK
IMQUIK's Avatar
The Glycol will eat your motor up!! Get it out ASAP!! :smash:
Old 02-13-2003, 09:32 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
if :skep: come clean :D warm it slowly then dump it.
Old 02-13-2003, 09:54 AM
TLewis4095
TLewis4095's Avatar
????this has got to be a joke, right??? There is no way to mistake oil fill with coolant tank....you are joking, right? :confused:
Old 02-13-2003, 10:12 AM
Mikie C
Mikie C's Avatar
vetterdstr :cheers:
:iagree:
Antifreeze will kill the bearings. I would let it drain for a couple-4 hours. Good Luck
Mike :)
Old 02-13-2003, 10:14 AM
Z06 Mike
Support Corvetteforum!
Z06 Mike's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: What happens if you accidentally pour in Coolant instead of Oil into motor? (TLewis4095)
"Put your hands in the air"..."Move away from the Corvette."
:eek: :eek: :eek:
Old 02-13-2003, 12:21 PM
BigBlue
BigBlue's Avatar
Default Re: What happens if you accidentally pour in Coolant instead of Oil into motor? (OCMike)
Buddy changed heads on his truck and dumped about a quart or more of coolant in his oil. Then tried to start it without changing oil. He is now in need of a new crank and bearings. Engine seized up on him. WHen we pulled the oil out, it looked like milk. It was that white and extremely thick.
Old 02-13-2003, 12:26 PM
vetterdstr
vetterdstr's Avatar
:eek: :eek: :eek:
:lol: :lol: :lol:
vetterdstr :cheers:
To What happens if you accidentally pour in Coolant instead of Oil into motor?
Old 02-13-2003, 01:19 PM
tabbruzz
tabbruzz's Avatar
Find a dealer or garage that has machine that flushes the oil. Try to find a machine made by Envirolution. It is completely safe for your car and you will be able to see everything that gets flushed out. Alot of major dealerships use these machines and are very pleased with them.
Tony
Old 02-13-2003, 01:25 PM
MikeV
MikeV's Avatar
Default Re: What happens if you accidentally pour in Coolant instead of Oil into motor? (tabbruzz)
Don't start the car. The coolant will go to the bottom of pan. Drain oil and refill with regular oil to flush. Start car and let warm up. Drain oil again and check for coolant in bottom of drain pan. Repeat if needed. Then change filter and refill with Mobil 1. No harm if you didn't run the motor with it in.
MikeV
Old 02-13-2003, 01:30 PM
mods to come
mods to come's Avatar
:eek: :eek: :eek:
:lolg:
Quick Reply: What happens if you accidentally pour in Coolant instead of Oil into motor?
