Lingenfelter siamesed bore LS-1 block
Lingenfelter has a $3350 alternative to the C5-R block. He's basically sleeved the LS-1 block with larger, siamesed cly liners. If anyone has used one of these, I have a question:
I think the stock liners are poured or sprayed in, to ward off potential leaks between the water jackets and the crankcase. The Lingenfelter liners are pressed fit with "o" rings to seal against water leakage. Is anyone aware of any reliability issues? sj
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Re: Lingenfelter siamesed bore LS-1 block (speedjohnson)
The stock sleeves are cast in place.. The C5R block has thicker water jackets to better support the larger sleeve..
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Re: Lingenfelter siamesed bore LS-1 block (nevrenuf)
I'm currently thinking about a 2-year savings plan so I can get a C5R427 :D
Re: Lingenfelter siamesed bore LS-1 block (Mean Green 2000)
I think this is the new Darton sleeved LS1 blocks that LPE is selling.
Re: Lingenfelter siamesed bore LS-1 block (93Polo)
Keith
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Re: Lingenfelter siamesed bore LS-1 block (kromberg)
Yes. The Darton sleeve is much stronger than the stock sleeve which allows it to be bored out to 4.155" :)
I know ARE spent a few years developing and testing their Darton-sleeved block to get it where it is today.. You could probably bore it to the same but ARE prefers to keep it to 4.100" and maybe 4.125" for strictly N/A uses..
Re: Lingenfelter siamesed bore LS-1 block (MattG)
I believe that Nineball over on the LS1tech board is running a 4.155" bore by 4.00" stroke for a 434 CID motor.
Keith
Keith
I know of another friend of mine that has had some issues with a bore that big as well. However, Im not sure if they have came to the conclusion that the sleeves were to blame yet.
Regardless, these engines I just mentioned are MTI resleeved motors, whom I do not believe use Darton sleeves.
[Modified by MattG, 1:41 PM 2/4/2003]
MTI is not using Darton sleeves. LPE has used the DArton's for awhile (according to them) and they have held up to high HP high boost motors.
This sleeve design is a wet sleeve design just like a big diesel. It amkes its own deck, so sleeves slipping won't be an issue like pressed sleeves.
JL pretty much warranties everything for 2 years and bases his reputation on reliability so I would think he spent time with ths setup before he would put his name on it. My bet is its pretty reliable.
Re: Lingenfelter siamesed bore LS-1 block (NEPTUNEBILL)
Re: Lingenfelter siamesed bore LS-1 block (J-Rod)
LPE has not done a whole lot of testing yet, from what I understand. I think Cartek jumped in first and pushed everybody else into the ring before a bunch of testing was done. I do not know of any 4.155 darton sleeve block going through 300 shots or 10# of boost.... yet ;)
