Voltage varying
Voltage varying
My Z06 voltage is varying. I can start it and it will be at 12.5 volts whole time running. Then shut it off and next drive will be at 14 volts. Then next time 13 volts. I'm guessing my voltage regulator is going bad. Really question is is the regulator built into the alternator. If so can I replace just the regulator or is it time for alternator rebuild.
Daveinnola (04-23-2024)
