C5 corvette rear knocking sound
I have a c5 corvette with a knocking sound coming from the rear of the car. It is speed based and goes away with a clutch in, or if I put the car in neutral from what I can tell. (Loud exhaust)
*changed diff oil, and inspected. Looked fine.
*new axles either correct torque on the 33mm nut. *new wheel bearings.
*Wheels don't look damaged
Any help would be appreciated.
Video below
https://youtu.be/-OcZjb9gArU?si=khSXU190wypkxI1B
Video below
Received 19,702 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
You say it's speed based, but also say that it goes away with the clutch in. Seems to me those 2 ought to be mutually exclusive. It's for sure not RPM based?
