Temp guage doesn't match digital reading.
Cruising
I was letting my engine idle to check if my coolant fans turn on at the correct temperatures. The coolant temperature levels out at 201° on the digital readout and it was one tick below the 220° reading on the analog gauge. So that would mean each small tick on the analog gauge is 20°. The range of the gauge is from 100° to 260°. So doing the math backwards that means the bottom reading for the coolant is 60° which would be not match the 100 and the same for the max temp. Does the gauge go in increments of 5° above 220 like our speedometer changes tic values after 100 mph? My car is up on stands so I can't just drive it around and check it but I just noticed it and all of the other gauges are linear. Could this be a sensor problem or just how the analog gauge works?
The temp and speedometer sweeps are not linear. The temp gauge below 220 is 15 deg f per minor tick. Above 220 it is 5 deg f per minor tick. I think the temp gauge is in pretty close agreement with the digital gauge and looks to be within a few degrees of the digital reading. I think they did it this way because the sweep of the gauge would be too large if a linear scale was used and it allows greater fidelity of the reading in the areas where the gauge reading is used.
Received 2,267 Likes
Mine does the same thing. The analog gauge is more a guideline than an exact reading, regardless of the gadiations. .The digital temp is pretty accurate.
