Coolant leak from the reservoir?
I’ve been having this coolant from the passenger side. The weird thing is that it drips from the wheel well/fender trims.
I put dye and no leaks were found under the hood not even any of the hoses. Could it be that my reservoirs got a crack in it?
How common do these things crack anyways?
The following 4 users liked this post by Lawandorder:
Age, as well as hot / cold cycles eventually causes plastic to become brittle and crack. Rubber components (belts and hoses) also deteriorate for the same reasons. This is not unusual for a 20+ year old vehicle.
The following 4 users liked this post by Tron Z:
Received 2,686 Likes
2018 C5 of Year Finalist
Common issue. Replace with a new reservoir and cap and consider it a good run for a 20+ year old piece of GM plastic.
