gas leak.. most likely cause?
Moderator
Took the car out (2000) and got a "resrve fuel" warning light.. which is really weird, since I never let it go under 1/4 tank, almost never under 1/2. Go to gas station, no gas smell (and saw no noticable stain on the garage floor), filling up, I noticed a fairly large spill from under the car. Get down on the ground, and sure enough there's a drip. Close enough to the exhaust that I called a flatbed.
Car's in the garage, and a drip maybe ever minute.
Likely cause? cross over pump? Drip seems to be comming from around center of car, maybe slightly closer to rear/driver side.
2023 C5 of the Year Winner - Unmodified
Might also be the filler neck, that was the cause for the fuel smell on my dad's '03.
Moderator
Mine has a fuel leak as well. Leaks when it’s transferring fuel from passenger side to drivers side. It leaks on the drivers side into the fuel tank skid plate then drips out of the rocker panel. I’ve got it in the air now about to start tearing into it but I suspect the crossover tube. My car had been sitting for 16 years, so I’m guessing that one of my lines is rotted/cracked. Like so many of the other parts I’ve replaced lol
Received 19,388 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech for continued discussion.
Moderator
Thanks @Vetteman Jack
To others that have done this -- how difficult is it to get to the crossover?
I don't have time to do this myself. I'm debating whether to have the local texaco do it (I've devleoped a relationship with them, and they have a decent knowledge of 'vettes) OR, I could ship it back to the shop in NY that did all the engine work (super/cam/etc) for me -- it's withing flatbed distance, so not a huge deal.. I'm leaning towards sending it to the NY shop, especially if this is a multi day thing, since I know he'll keep the car inside,and I know he knows c5's inside and out. And if this is the crossover, definitly a c5 - specific thing.
First thing, as well as easiest and cheapest thing to do, is replace the fuel filter. A number of years ago, I changed the fuel filter on my C-5, and a short time later, I smelled gas, but only when the car was running. Turned out the "O-ring" on the new filter wasn't sealing properly, and fuel was dripping. As you've already noticed, the fuel lines run right over the exhaust, so in my case, the small droplets were hitting the hot exhaust, and evaporating almost immediately, therefore it wasn't easy to see the problem. And with the engine off, therefore the fuel pump off, no fuel was being pumped, so no leakage. Another new filter fixed the problem.....
Alley Oop (03-04-2024)
Received 1,217 Likes
Until you fix the leak, I urge you to park the car out of the garage. Years ago a neighbor had work done on their gas tank and put the car in the garage. The next morning when he got up he hit the open door switch and then BOOM; 1/4 of the house was gone. He survived but barely.
Moderator
St. Jude Donor '06
ALmost gaurenteed to be the fuel filter on the driver side frame rail. It drips on to the exhaust tube. As previously mentioned, the orings are easily damaged and also damaged by ethanol.
My 97 used to go through a filter every 30-40K miles. If I recall, a Buick Rendevous filter from like 2003 is what ended up solving the problem.
Moderator
St. Jude Donor '06
On a lift, it would be a 5 minute job, but when I did it, I backed the rear of the car on to a pair of ramps, then wiggled my azz under the car, with tools nearby. It was awkward, but I got it done.....twice. Once to install what turned out to be the defective filter, and once again, to replace it, with what has turned out to be a good one.
Moderator
Moderator
Couple of things:I understand the filter is slightly different for the 99-newer model. But I think it’s in the same area as the 97-98 models. On my 97 it was easy to access. Required a special tool to remove the connector. Pliers could work too. Anyway, it was a bit of a pita due to the quick connectors. But other than that I did it in my driveway on ramps.
Moderator
I bought the fuel filter, but it doesn't come with o rings... anythoughts on what size / lkind of orings to get? I want to throw this on the lift once and be done with it.
Moderator
so I got the car up on the lift, ran it for a few mintues, and not a drip. Now that I look at it, looks like the fuel filter is brand new (which would make sense, I think we changed it when we put the super in), and the cross over tube is bone dry.
What could possibly have caused this? maybe overfill when I put the fuel in, that somehow I missed?
