Revolution Electronics C5 Corvette ABS Code Clear
Revolution Electronics C5 Corvette ABS Code Clear 14019 module.
Anyone got one of these or know someone who has ? Alternatively a device that does the same thing ? Thanks in advance
I've reached out to them and they will not sell because of liability. I even asked about purchasing plans or just unassembled parts. No luck with that either. I've not found anyone that was able to get the product either. Please do let me know if you by chance find someone with it.
V8 YEA (02-04-2024)
jlturpi (02-04-2024)
I'm confused. If they won't sell it, why did they make it in the first place??? Or will they sell only to all out racing car owners? Or?? Also assuming this makes the "upstream" electroncs think the EBCM is alive and well when it isn't? Sorta like the O2 sims? This thread could use a bit of explaining.......
Apparently the ECBM sends a pulse signal to the BCM to tell it it's working properly, this module just does that. The chip is an of the shelf one that needs programming. I'm not good with electronics so I wouldn't know how to build one but I'm sure someone here would be capable.
