1997 Corvette Propeller Shaft/Input shaft help
5th Gear
Hi everyone, so my torque tube was stuck so force was really the only option lots of corrosion and in doing so the teeth of the propeller shaft/input shaft got chipped. I can’t find any part number for it or replacements. I see that there’s an aftermarket one but it states for 01-04 models only. Does anyone know if it can be used in 1997 they look very similar or should I just clean it up and use it as is?
5th Gear
5th Gear
Try RPM transmission in Indiana.
Homepage - RPM Transmissions
Speed Inc has my old 98 splined shaft like the one you need. Call and talk to Tony. My housing was broken and they ordered a complete 2001-2004 assembly from RPM when they installed my clutch. They should have my old one they could sell you, if they havent sold italready...
Performance Parts for Chevrolet Camaro, Corvette, Cadillac CTS-V, ATS-V, Dodge Hellcat - Speed inc
The old shaft looked really nice
Rectum? Hell, I broke the damn thing. Started as a hairline crack. they never got the old bearing out.
5th Gear
Prop Joe (01-08-2024)
https://www.homedepot.com/p/General-...KNLCyHXNBrQ4Gg
Don't use the round one in the set, use the one that is kind of oval, or ogive shape to it:
https://en.wikipedia.org/wiki/Ogive
Definitely worth a shot, blend it and see what it looks like... Other wise check those links I gave above.
May the force be with you!
5th Gear
So I ended up cleaning up the shaft and there’s lots of holes from corrosion. I thought of just running it as well but it seems like too much a risk for all this work . But definitely if that was the only damage I’d do it my mechanic also recommended I just file it.
