Kooks headers leak at flange (1st gen)
Kooks LT headers exhaust leak and P0430
Hello. I have a set of Kooks LT headers on my 99. They are the original 2 bolt collector / flange design. A few years ago I developed a leak in this area. I tightened them a bit and that seemed to solve the problem. I have very bad leak that you can smell while idling and driving even under no load. I also have a P0430 code currently.
I am going to check the leak this evening. Any suggestions aside from trying to tighten them up? I really don't want to over tighten them.
Thanks!
Thanks!
I sprayed the rest of the exhaust under the car. E.g., Where the catted x-pipe meets the mid pipe and the collector / flange area where the LTs from the engine bay end. The collector / flange area is a ball and socket joint type that is held together with a 2 bolts flange on either side.
I also sprayed the soapy water mix on the exhaust manifold area and there is some bubbling there. Looks like the exhaust manifold is leaking too. Could the headers be cracked or is this simply bad gaskets at this point? I think I used new OEM gaskets when I did this install many years ago.
In summary, I have two problems.
1) A big enough exhaust leak that makes driving pretty un bearable unless you are moving down the road with the windows open.
2) P0430 code.
