Clutch Problems
Clutch Problems
I had a Centerforce dual-friction clutch installed about 4 months ago. It is making a tapping noise when I have the clutch pedal all the way out. It seems to get louder in cold weather and when the A/C is turned on. I can make it go away be pressing the clutch in approximately one inch. Sometimes I can push the clutch in a few times and let it out again and the noise goes away. The folks I had install the clutch said the clutch seemed fine but it is embarrassing sitting at a light with a loud tapping noise going on like my engine is about to blow. By the way it never did this with the stock clutch. Anyone have any ideas?
Thanks!
Thanks!
Re: Clutch Problems (topgun)
If you are getting a vibration along with the sound then one or more of the weights on the centerforce are stuck out of position.
You could not pay me to put one of those in my car. I have had nothing but bad experiences with CF clutches. Too long a story to go into here.
Cruising
Re: Clutch Problems (jeromet)
I had a similar knocking problem at idle.
I could make the knocking stop by putting a little fore or aft pressure on the shifter while in neutral, or by depressing the clutch an inch or two.
My problem turned out to be a bad clutch release bearing.
Good luck in solving yours.
