Passenger side speaker not working
My passenger side door speaker isn’t working. It will once in a while kick in, usually when I’ve driven over a rough section of road, it will then kick off for same reason. I thought it was a broken wire/ loose connection or bad speaker. Took off the door panel, turned on the radio and played with the wiring with no change. The wires to the speaker all look good and the connection is clean and tight. I tried to move the wiring bundle around that comes into the door and still no change.
if you listen carefully you can barely hear sound coming through the speaker.
I got a used speaker off of eBay, swapped it out, and no change.
Any thoughts on the cause?
I'd check the L-R balance control just because but since it sometimes comes back on a rough road it has to be a bad connection. Could be internal to the head unit, the amp, wire broken inside the insulation, wire pulling out of a connector or several other things. Without special test gear you're in for a lot of testing.
Might find some tips in the C5 audio thread: https://www.corvetteforum.com/forums...audio-faq.html
Happy hunting!
Happy hunting!
