Check engine light on
These codes are displayed
B2282 And B2284. they refer to left door control module. I've tried resetting codes but they return after a short while when the check engine light comes on. Can anyone help please.
Zen Vet Master Level VII
The left door is the most complicated as it hold the most controls. Have you tested (pushed the buttons and see if it works as intended) the control panels? Mirrors, windows, locks...?
Are your codes "C" current or "H" History----- it makes a difference? Also, do you have a wiring diagram handy from your FSM? You might want to check everything that is connected to that circuit. The ground wires/mounts are pretty persnickety on C5 and you may have an intermittent ground issue.
Johnny Hardcore (05-07-2023)
Codes are H. I don't have a service manual. Even though the codes are H and I have reset a number of times the check engine light is displaying after a few miles. There are no other codes and everything works as it should. Suggestions will be greatly appreciated. I will need Pa state inspection soon and if the check engine displays, It won't pass.
What else is happening/error messages are you getting? Door control module failures won't throw a CEL.
I think your edit and my post just crossed paths. The H codes may go away with a battery disconnect. The CEL is another story. But if it's running right and your confident it's electrical...and battery is good...start with cleaning your grounds.
The large majority of gremlins in the C5 electrical system are caused by corrosion within the ground plugs.
Helpful link:
https://www.corvetteforum.com/forums...tion-long.html
I've also had other issues like "reduced power" that were caused by a tiny frayed wire in the door accordian wire loom that connects the power to the door.
Helpful link:
Moderator, Tech Contributor
Received 2,133 Likes
Other than the 2 “B”codes what other code to you see for the check engine light…those B codes won’t illuminate it…anything that affects the cars emissions will turn on the MIL.
CEL appeared last fall just before I put it away for the winter. I added fuel stabilizer and fuel. On the way home CEL displayed. I retighten gas cap and reset the codes which were B2282 , B2284 and U1064. Went for a short ride and it was fine. Thought tightening cap solved problem. Took it out of winter storage and drove it a few times and CEL displayed. Checked codes and only B2282 & B2284 showed. I checked the 2 grounds in the engine bay and both were show room clean. (the car has 14,000 miles). I also verified that the driver's door module wiring appeared to be tight and in good order. I did not open the contact units. Then reset the two codes. Went for about a 5 mile ride and everything was ok. Following day when about a mile and the CEL displayed. Same two codes.
Again those 2 door control module DTC’s will not illuminate the check engine light and cleaning those 2 grounds behind the headlight buckets are not involved in the door modules…this is the troubleshooting tree…the U1064 is a no comm with the BCM…you need to access those 2 circuits and check for a bad connection or high resistance in those 2 circuits…a visual inspection is not good enough…this is not a ground problem.
Thanks for your thorough replies. I don't have the tools or skills to diagnose using the info you provided. I checked battery volts=2.7. Are you referring to opening and checking the two connectors in front of the accordion connector in front of the drivers door?
I really appreciate your efforts. Also, what else could be triggering an inconsistent CEL? Coolant temp, oil pressure and temp. and everything else appears normal from my limited knowledge viewpoint.
I would seek out an auto-electric repair shop in your area…they would be the best to diagnose this…a former co worker of mine owns Walt’s Auto Electric in Stroudsburg…looks like he’s 24 miles away.
Used DIC. Problem first occurred shortly after getting fuel last fall. I have read on the forum where a lot of members had to replace their caps. Some 2 or 3 times. My problem is intermittent and everything seems to be working fine. I'm puzzled as to how the CEL comes on but no codes other than the ones I mentioned previously. I really appreciate you taking your time to help me with this issue!
With all the junk and counterfeit parts people are getting these days from China it’s no wonder why members are changing gas caps 2 or 3 times and it may not even be the gas cap…if you decide to let Walt look at it I’ll send him a text and explain what you have going on with the car…if you want to tackle this yourself remove the connector from that rubber accordion boot you see when you open the door…disconnect the connector and check where the orange wires are connected to…they are in the wiring diagram.
Ok. Lets do that. I am dealing with a family matter now...my daughter and her family are moving. I will get back to you when the move is complete. If you have any other thoughts in the mean time, please reach out.
So you want to wait before contacting my friend ??..if you want to inspect that connector you may find some corrosion.
