Stock LS1 piston rings
I bought a set of Enginetech piston rings for my LS1 engine. I checked the end gaps before installation and the top rings were with 0.024" end gap. I checked this with all top rings in each cylinder and also in the bottom area where the piston hasn't visited. All other rings were with proper end gaps but the top ones are garbage.
Since it was a very long wait and quite expensive to get those rings in here (Finland) in the first place, I wouldn't want to do the same mistake again. Is there a good source for file to fit rings and can they be sourced as a top ring sets?
IIRC, and I may not , you're supposed to have roughly .004" per inch of bore diameter. This means you should have only .016"-.018" max gap. With a .024" end gap on a 3.900" bore, you could run a 500hp shot of Nitrous and still not worry about butting the ring ends !!
Too bad I'm making this a stock engine. I could use all the power adders in the world with these.
Enginetech replied they need to fulfill SAE standards, not OEM ones... Though they admitted these wont fill even SAE ones.
I already have a ring filer. It's unable to make too short rings longer though
