axle nut torque
Received 1,252 Likes
St. Jude Donor '21
New nut and red loctite as well. There is a GM TSB where 04 models get torqued to 160 lb feet. Makes me wonder why earlier C5s wouldn't as well......
Received 19,427 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
Also of note-- be sure to do this torque process with the parking brake set. It will make the process far easier and more precise.
When disassembling my car for a differential repair, I found one of the axle nuts was much too loose (one side wants to loosen and the other tighten just from driving). Read through all the threads on original torque, service bulletin torque, broken axles from over torque, ... Decided against torquing above the original spec. I used new nuts with red loctite and marked them so I could see if it rotates. Sure enough it rotated during my first track event.
In the end I just double nutted that side and it hasn't moved in years.
St. Jude Donor '21
I'd like to see that bulletin. I torqued mine to 120, which in the grand scheme of torque is "damn tight". I didn't use any loctite of any flavor.
Like I said, makes me wonder why not include the 97-03 C5's. I like the idea of marking your rear axle nuts and then you can tell if they have moved.
Tapping or Scraping Noise From Rear Wheel Area (Replace Wheel Drive Shaft Nut) #07-04-95-001 - (09/26/2007)
Models: 2004-2008 Cadillac XLR
2004-2008 Chevrolet Corvette
Condition
Some customers may comment on a tapping or a scraping noise coming from the rear wheel area.
Cause
This condition may be due to the torque on the wheel drive shaft nut relaxing over time.
Correction
Replace the left and the right wheel drive shaft nut following the procedure below.
Remove the center cap from the rim.
Remove and discard the wheel drive shaft nut.
Apply LOCTITE™ 272, or equivalent, to the threads of the axle shaft.
Install the nut and tighten to the new specification.
Tighten
Tighten the nut to 215 N·m (160 lb ft).
Install the center cap to the rim.
Important: The vehicle should not be driven for 24 hours following the repair in order to allow the thread lock to cure.
Parts Information
Part Number
Description
Qty
10257766
Nut
2 (one per side)
Warranty Information: Labor op F9712 0.3 hr.
I have done the same as well but I have also torqued down some when replacing axles when I worked at a couple different shops. My vette I would just impact it and try that mark method to see if it moves but I have never had to replace one of mine though. I think it would be fine lol. But I do know their are torque specs for a reason.
Received 1,769 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
My 300ft-lb battery operated gun cant do any more damage than the 400ft-lb engine turning them, lol. Thats my thought process anyway.
