Who is your "go to" for wheel hub/bearings?
My newly acquired C5 is going to (and has) seen a mix of street use and HPDE. It apparently needs all 4 wheel hubs. Who is your go to? Won't get the cheap economy set from Rock Auto, but also would prefer not to break the bank. Plan to clean and repack after each track day.
One does not clean and repack a C5 hub. For track use I'd get the schwanky SKF racing hubs.
https://www.lgmotorsports.com/skf-racing-hubs.html
This is the only upgrade over stock that I'm aware of. Anything else will be the same or worse, the only stock replacement I'd even consider is SKF. What makes you think it needs all 4 hubs? If the car is that neglected what else is wrong with it?
C5Luv'R (08-27-2022)
If you plan on tracking it, definitely spend the coin for the beefed up SKFs. If not, regular SKFs.
Banned Scam/Spammer
Location: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Received 3,916 Likes
This MOOG one is currently on clearance at RockAuto for $98/each +shipping:
https://www.rockauto.com/en/moreinfo...sn=__GIP__66__
I'm thinking of going with the SKFs up front and Moog in the rear.
Another vote for the SKF. It is actually a newer technology bearing then the OE design. I was told from a very good source that LG Motorsports worked with SKF specifically to create a durable track-capable bearing for the C5/C6 Corvette.
ArmchairArchitect (08-28-2022)
