Car will not start
Car will not start
Was driving and stopped to get gas and will not start back up. All electronics work horn, lights and radio. When I turn the key the only sound I get is a click in the area of the fuse box on the floor.
Zen Vet Master Level VII
I would start at the battery also. When is the last time you checked the battery cable connections for corrosion or tightness?
I have had that happen on other cars where a simple hand-twist of the terminal on the battery got it started and home, then followed with a good cleaning.
Have the battery tested or messure voltage across the terminals should be around 12.5 volts. The clicking noise you hear is the TDR it is the relay that sends power to the starter solenoid to crank the engine over. You could have a bad TDR, loose cable connections at the starter solenoid, or has been mentioned the starter could be at fault.
Forgot to mention that you can determine if the TDR is or is not the cause of the no crank condition. The TDR is located above the BCM it has four wires two small gauge yellow wires and a red and violet wires, by inserting a wire jumper between the red and violet wires at the TDR socket if the car cranks over the TDR needs replacing, if nothing happens it's probably your starter. WARNING make absolutely sure the car is in Park or neutral before doing this as the car will crank over if nothing else is wrong.
The BCM is the body control model and is located behind the toe board in the passenger foot well area where the interior fuse box is located. A wire jumper is simply a small length of wire with the insulation removed on both ends that you use to jumper across two points.
Jamescool2715 (08-21-2022)
Moderator, Tech Contributor
Received 2,136 Likes
TDR stands for Theft Deterrant Relay, it is the relay that sends power to energize the starter. I second C5 Diag about having a shop look at your car as you have to have some level of technical knowledge to diagnose your cars no cranking problem.
I say go for it. Never progress of you don't aim beyond your current ability.
question I have a 04 vette , been having a couple problems one I’m dealing with this morning was my car didn’t want to start , it cranks sounds like it wants to start but dosent do . What would be the first move to do?
BEST to start a NEW thread instead of hijacking this one…makes following the thread less confusing…so is this a crank no start ??…if it’s slow to start have your battery checked…if it cranks normally do your heat the fuel pump turn on for 2 seconds when the key is turned on…you can try spraying Brake Kleen or starter fluid into the brake booster hose or PCV hose going into the intake manifold…if the car starts you may have a fuel delivery issue.
The following 2 users liked this post by C5 Diag:
Brandon G (08-22-2022),
Jamescool2715 (08-22-2022)
