Car doesn’t feel right on Aldan American coilovers
Hey all, i have an 03 Z06 that has the Aldan American coilovers, single adjustable, spring rate of 500lb front 550lb rears. Now driving around town it feels fine for the most part but on the highway at speed going over any bumps or dips or freeway expansion connectors it just feels very bouncy and not very solid, i don't know how to best explain it. It just doesn’t instill confidence in the suspension. When they were first installed i had the compression and rebound set to the soft side and it felt floaty, so i adjusted them stiffer one click at a time, driving the car for a few days after each click stiffer, and i am at the stiffest the compression and rebound will go now and the car just never seemed to ride good and tight at all. Do the aldan american coilovers just suck? I didn't do any other suspension mods yet other than the coilovers. Are there other mods i should do help the ride feel better? I really dont wanna have to shell out another couple grand to swap coilovers. I love the ride height and the way the car sits. Maybe the car is sitting too low and its causing a major decline in ride quality? Here is a pic of how the car sits right now. Sorry for the crappy phone camera quality. Any suggestions to help would be appreciated.
Received 3,112 Likes
St. Jude Donor '21-'22
As far as other suspension mods, you might want to try upgrading your sway bars. It wouldn't cost all that much, and would reduce body roll. I'm not really sure that it would solve your issue, but it would improve the overall handling of the car. Good luck!
The ride height looks great though.
c5arlen (07-14-2022)
Ride height looks little on the low side IMO to retain proper geometry and not getting on bump stops of the shocks. Spring rates seem "normal" given the use of the car.
Aldans never got a great reputation...so take that however you want. I have never used them but from what I read, they are front compression and rear rebound adjustable? So while they are "single adjustable" you are adjusting front compression only and rear rebound?
If so, this is what confused me about their approach as they are the only company doing that. 99% of single adj shocks are REBOUND adjustable. Compression is a "fixed valving" but I can't say that front shocks and rear shocks have the SAME valving as companies may make them different on purpose.
Make sure they aren't leaking...read stories of this happening too.
I've run Ridetech HQ and now I run Viking triple adj coilovers and have not had any issues as you describe trying to dial in the ride.
Quote.. "I didn't do any other suspension modifications".... You've changed the "integration" of the hole suspension system of a working, well designed, thought out system.... at least that what you've noted with your discription.... There are several elements that are incomplete, hence the C5 initial suspension integration is now in jeopardy... It's a matter of determining what steps you've missed by involving a professional suspension fixer... and you need him!
daveward (07-16-2022)
yeah the guy I got it from said the car is 100% original, bought it with 60k miles and it now has 70k. I'm in the San Fernando Valley, Burbank to be more specific.
Keep it stock or start the build.
snaitaz@aol.com (07-16-2022)
I'm no expert by any means so I'd assume the rest of the suspension will need changing to oem or aftermarket. If you want a shop look at it, I would suggest Edwin and Angel from Power house racing (818) 648-2057 Best Vette mechanics in SoCal and highly recommended.
You think because he added coilovers that the car is ruined LOL You realize there are SO MANY cars out there with coilovers that perform BETTER than OEM right?
IMO my simple vote/assumption is the Aldans suck or your ride height is too low...or both.
The following 4 users liked this post by smitty2919:
daveward (07-16-2022),
FYRARMS (07-14-2022),
Johnny Hardcore (07-15-2022),
miami993c297 (07-15-2022)
My car came with Penske adj. shocks that would accept coilovers. After reading about switching to coilers, I decided to stay with the factory leafs. Coilovers take a lot of adjustments to get really dialed in along with corner balancing after adjusting. I figured it wasn't worth the time for what I use the car for. I'm sure after some tinkering you'll get it right.
What are you guys talking about???
I would start by raising it up an inch or so, see if it improves. You may be bottoming out over bumps and definitely can mess up the geometry by going too low... Then start back in the middle settings and go from there. Good luck.
Ride height is too low or adjustments are WAY off or Aldans suck or all three. Simple trial is to raise the car 1/2" to 1" and see if that improves the ride.
I appreciate everyones help, Im gunna see if I can raise the car up slightly and see if there's any improvement, although I do want to try and avoid the horrid 4x4 look alot of c5's seem to have.
A couple good replies in here and a lot of dumb ones. Typically lowering on old shocks causes issues, these are new out of the box. Are you bottoming out Eric? It's quite possible the Aldans suck, and you are very low, but that shouldn't cause an unsettled feeling going in a straight line unless the car is underdamped or running out of travel. I imagine though that those springs are withhin the realm of what the shocks were intended for. Have you contacted Aldan yet? If you want to stay that low, I'd add some lowering spindles to get the geometry back where it needs to be and return some travel to the car.
1/4 mile/AutoX
all I can add, wife and I have the aldan's on our C6 Z06 and it drives and handles great , it does have poly bushings all around !!!
