C5 Overheating BAD!! Help!
Sounds like you were around town type driving.
First thing I would check would be the fan operation, both on low at 226 F, both on high at 235. Both on aqt 185 with A/C.
I have had several fan motor failures.
zztopo (06-17-2022)
I have done a 80/20 mix water to anti freeze my temps never get over 210 degrees, Mycar is cammed procharged making over 800 hp. I live in fla so it does not freeze here.
Thanks, that was what I was thinking, but I saw a YouTube vid where the dude said he could not see the fans. I guess I gave up too soon after hearing that. I will be checking that tomorrow. But not the wire a light into the circuit idea, I am not that competent nor confident.
My C5 only gets to 218-220 F. with the AC off. Perhaps I'll try to activate the AC and check the fans; if the needle starts heading to the right, I will shut the engine down. Thank you.
Nice numbers. My 2010 SS Camaro dynoed 769 rwhp, charged and cammed with every single bolt on and tuning. But it's a moot point now. The SS is a pile of ashes as of 4 months ago.
If u have someone by the fans , when u turn on a/c u will definitely hear the fan kick on. Dont b dumb like GRINDER. He had someone turn on the a/c and he checked with his fingers. Maybe thats why he always giving me the bird when he wavies at me when he gets home. I just thought he didn't like me..Last finger standing. dumb butt. God if i told u all the things hes done working on peoples cars, i would have to have finger replacements.
Thank you very much. I was hoping for a "false alarm," but it is real. I just took it for a quick spin without the AC on, and it stayed at 218F* F. What a shitty time for the engine and AC to hate each other; we're breaking heat records with no end in sight! I guess I'll be sweating my *** off until I do what you suggested. I don't have $ for a new water pump. Question: I want to change to 160* stat. I don't like my engines running that warm in this goddamn heat. Good idea?
Again, thank you for responding.
Ok guys poked inside the engine bay to check out the fans. The passenger-side fan is the low speed fan, right? It kicked on at around 215*. With that said, I tried to see the other fan (driver's side) but I can' t see it. Am I missing something?
Also I discovered this behind the airbox. Did the shop disconnect this when they installed my new MSD 2 step?
Should be two fans they both turn on together on low speed at the lower temp set point, and then both go to high speed when the higher temp set point is reached.
Do the 2 fans sit side-by-side. I got shitty 61 year old eyes, I'll double check tomorrow to see if I can eyeball both fans.
#34
I'm thinking condenser overheat and/or leak in the AC system. I'm thinking the fans are ok. If the fans are the problem, then (I think) my water temps would be high when running without the AC. The C5 ran at a steady 215* today, and it is still hot out.
Hopefully, the C5 just needs a blow job.
Just like me.
Just like me.
#38
Received 2,275 Likes
Is that 215° with ac on?
I was driving around today in the 90’s with the ac on and the water temp was holding about 200°. You may indeed have some blockage.
Check out this post…
https://www.corvetteforum.com/forums...post1605291551
zztopo (06-19-2022)
#39
Hey thanks!
#40
Just a quick reminder that in a stock C5 your stage 1 fan isn't even set to come on until your engine reaches 226°. Also it has conditions for the A/C.
If the A/C is on, the 1st fan should come on at 185° which means it should basically be on all the time if everything is working correctly as you have a 187° thermostat.
My first step would be making sure the car has enough coolant, then check the cap, then hoses and fans before I thought about the water pump unless your car is leaving puddles after being parked.
