Stainless steel brake lines Question
So I have upgraded my brakes to C6 Z06 brakes and when putting on the brake lines there is a nipple from the hard line that goes into the stainless steel brake lines. But the C6 lines won’t work. So I am assuming I just use C5 stainless steel brake lines?? Thank you in advance
I believe that there's a difference in brake line connectors. I recently changed mine to C5 specific stainless steel brake lines for my '04.
Same thing happened to me! I wound up reusing my C5 SS lines - which were almost identical in length. My story (with pics of the brake lines) here...
C6 Z06 brake upgrade notes - CorvetteForum - Chevrolet Corvette Forum Discussion
From your picture it appears to me that the left is a bubble flare (metric) and the right is a double flare (SAE). You could use the old hoses, or change the nut and re flare the hard line to use the new hoses.
Received 19,439 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
KRPTONT (10-14-2021)
