New 2002 C5 coupe battery
Costco has the Interstate battery for a good price and after looking for a new AC Delco I've stared to wonder if it's time to change brands to Interstate. I'm asking myself that since I use the car very little and it's stored 7 or 8 months of the year, what do I really NEED?
Can't wait to see the responses. I want to get something!
Get the cheapest battery you can get. Maybe even a motorcycle battery.
Then work your way up after those fail.
Any battery will work as long as it is the proper battery for a C5, I would recommend disconnecting the battery and keeping it in a cool place, maybe connect a charger at least once a month if the car doesn't get started during winter.
I have a couple of cars that I drive less than 1000 miles per year and a coach which gets driven every summer, but sits for 9 months per year. The batteries at Costco will serve you well (the battery on my Nova failed after 23 months and they did a straight exchange with me and gave me another 24 month warranty...they told me they did away with pro-rating). The other thing to consider is a battery tender. I run small pulse chargers on all my seldom driven vehicles (including the three 1100 CCA engine start batteries for my 8V92TA diesel two stroke running straight 40W oil in my coach). Always ready to start when I turn the key, summer or winter.
Here is my battery tender of choice...it will work on flooded, AGM, and lithium batteries...6 or 12V.
Is the Costco battery AGM or flooded? As a recent owner of a C5, it is my understanding that it's recommended for the C5 to use AGM due to the vulnerability of electronics located under the battery. For that reason, I went with the Optima red top. However, I buy Costco Interstate for my other cars. Recently, I had a Costco battery fail at 3 yrs/2 months into a 3 1/2 year warranty. I expected to get a few bucks credit on a prorated warranty. Nope. They gave me a brand new battery and said, "See ya!" I was blown away.
Dads2kconvertible (10-13-2021)
Go with an AGM battery (no particular brand) for the reason Njmurvin said (protect electronics). Do get and use a quality battery/float charger....I recommend the Battery Tender Plus. I hardwired the charging pigtail to the battery so can easily plug/unplug the tender when necessary. Good luck.
You will get an extra year warranty when you buy the Costco Interstate with your Citi card. My Costco Interstate would not hold enough charge to start my car last winter. The factory warranty had just expired. I contacted Citi card, filed a claim, and got a full refund.
One of the first things I did after purchasing a C5 in 2004 was replace the (rather new), name brand wet cell battery for an AGM I had in another vehicle. I did this because back then I was reading almost daily accounts of wet cell batteries leaking in the battery compartment of the C5 and doing significant and costly damage to vacuum lines, the wiring harness and the PCM. That AGM lasted more than 10 years when I replaced it with another AGM, this time an Interstate. I would highly recommend using an AGM battery, particularly so for a C5 where the battery sits above the PCM.
The benefits of using an AGM in the majority of my vehicles, from cars to trucks, Motorcycles and lawn tractors, far outweighs the cost in my personal experience.
The current Interstate battery listed for the C5 Corvette is the MTZ-78. This is the current replacement for the battery in my car, the MT7-75DT (Dual Terminal). I don't know if Interstate offers the dual terminal in the AGM battery any longer. You can purchase adapters to convert a side terminal battery to a "post" battery if needed.
I also have it hardwired with a pigtail to plug in my Battery MINDer.
Good luck... GUSTO
Good luck... GUSTO
Interstate is fine, I installed a Group 78 AGM Duracell earlier this year, from Sam's Club, my last Duracell (non AGM) lasted over 5 years without using a maintainer, all modern cars, especially
a Corvette need the most powerful battery you can fit .
The Corvette doesn't need a more powerful battery than any other well optioned car. It takes no more battery power to start the car than any other V8 needs and the car (any car) runs off the alternator when running, not the battery.
Well optioned cars need a powerful alternator, not so much a powerful battery.
Well.....bit of a difference of opinion on the need for a more powerful battery. One absolutely needs more CCA the further North you go...you won't last long with a low CCA battery in International Falls in January. Also, the higher the compression in modified engines, the more juice you will need to start swinging the crankshaft (unless you have compression relief valves) to start. Been there done that.
I stand by what I said based on normal circumstances.
