2000 c5 corvette strange noise from far left side of instruments cluster.
When I get into the car, I hear a screeching noise from the far left side of the instrument cluster and it is very annoying. Please tell me I don’ have to pull the cluster.? I am thinking it could be the ding ding alert is going bad. Thx
Yes it is the chimes in the car. The chime speaker is part of the instrument cluster. To fix it the cluster will need to be replaced or the speaker unplugged.
Gary
Gary
The problem is not the speaker itself but the electronics that drive it. To fix you will need to replace the cluster. If you don't want to replace the cluster you could disconnect the speaker, you still have to remove the cluster from the car.
Gary
Gary
I have removed the dash several times to fix the AC issues with vents, so while I have the dash off are there any other things I might want to check?
The whole dash does not need to come off. Only the center console,radio surround and knee bolster. Steering column would have to be dropped (not removed). Then the gauge cluster can be removed.
Nothing additional I would suggest at this time.
Gary
Gary
