Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-22-2002, 08:09 AM   #1
GS057
CF Senior Member
GS057's Avatar
Default Stock injector size for 2002 LS-1 and Z06?
What size are the stock injectors on the a stock 2002 LS-1 and Z06? There is a set on e-bay that the seller claims are 2002 stock Corvette 30lb. injectors. I used the buy-it now and want to make sure he is correct before I send the payment.
Thanks,Michael
:confused:
GS057 is offline   Reply With Quote
Old 12-22-2002, 09:51 AM   #2
JaminJ
CF Senior Member
JaminJ's Avatar
Default Re: Stock injector size for 2002 LS-1 and Z06? (meyre1)
If you did the BUY IT NOW you own them you should check on items before you BID Read the Ebay, Disclaimer........... :yesnod:
JaminJ is offline   Reply With Quote
Old 12-22-2002, 11:22 AM   #3
TooManyIDs
CF Senior Member
Support Corvetteforum!
TooManyIDs's Avatar
Excerpts from:
http://www.vetteguru.com/mods/howto/
Not aware of any changes for 2002.
97-98 = 28.4 lbs/hr
80% duty cycle rating: 45.44 Crank HP x 8 = 363.52 Crank HP
100% duty cycle rating: 56.8 Crank HP x 8 = 454.4 Crank HP
99-2001 = 26.4 lbs/hr
80% duty cycle rating: 42.24 Crank HP x 8 = 337.92 Crank HP
100% duty cycle rating: 52.8 Crank HP x 8 = 422.4 Crank HP
Z06 = 28.2 lbs/hr
80% duty cycle rating: 45.12 Crank HP x 8 = 360.96 Crank HP
100% duty cycle rating: 56.4 Crank HP x 8 = 451.2 Crank HP
TooManyIDs is offline   Reply With Quote
Old 12-22-2002, 11:41 AM   #4
GS057
CF Senior Member
GS057's Avatar
Default Re: Stock injector size for 2002 LS-1 and Z06? (2000 Pewter Hardtop)
Pewter Hard Top, I do not think you are committed to buying the item if the seller misrepresents it. I used the buy it now because it was $100 buy it not for 2002 Corvette 30lb stock injectors with 7 miles on them. If he is correct that is a great deal. What are the parts numbers for the stock ls1 and Z06 injectors?
[Modified by meyre1, 4:42 PM 12/22/2002]
Old 12-22-2002, 03:26 PM   #5
GS057
CF Senior Member
GS057's Avatar
ttt
Old 12-22-2002, 04:56 PM   #6
JaminJ
CF Senior Member
JaminJ's Avatar
it is prudent to know what you are buying, before you bid. it is up to you not to be a victim, reduce the possibility of ripoff, fraud or just buying the wrong part and blaming the wrong person. you should know what you need. that is what im trying to tell you. :cheers:
Reload this Page Stock injector size for 2002 LS-1 and Z06?
Tags
02, 2001, 2002, c5, corvette, injector, injectors, lb, ls1, rating, size, stock, vette, z06, zo6
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
