98 Convertible Gas Smell
I have been experiencing a gasoline smell when I fill the tank. It's not just gas station fumes, it stays with the car for a while. I can find no leaks, and I stop the pump on the first shut-off. It may be my imagination, but it only seems to do it when the top is down. I have to ventilate my garage for several hours and then it seems to go away, and stays gone until fill up with the top down.
Any similar problems out there? Suggestions?
the gas tank vents through the charcoal canister. you probably have a plugged vent path or the charcoal canister is saturated with liquid.
Is your car possibly a flood damaged car?
Moderator, Tech Contributor
Received 2,138 Likes
Received 1,217 Likes
BAC, do you 'top' off your tank at fill up? I once had the same smell but only after I tried to squeeze the last drops into the tank. Now I fill until the nozzel auto stop engages. No more top off and no more smell.
SteveBougon (09-27-2021)
