AC bracket bolt sizes
Hello all. Thank you for taking the time to look at my post!
I can find the stud (2), which I will purchase. But I figured I could just source the rest of the bolts myself (3, 5, 6, and 7)... well, I can’t find the bolt sizes. The vehicle is a 2002.
I’ll update the part numbers as I get them.
any help with the sizes or part numbers would be greatly appreciated!
2: 12556447 - M10 X 1.5 X 127
3: 11515768
5: 24503609 replaced by 11588751
6: 12552922
7: 24504202 replaced by 11588751
8: 11517996
11588751 - M10 X 1.5 X 95
3: 11515768
6: 12552922
8: 11517996
3-M10X1.5X40
5-11516714 M10X1.5X110
6-I see just the part # no size
7-11509202 M10X1.5X90
8-10X1.5
That's all my parts catalog shows
8-10X1.5
Cruise-In VI Veteran
Not recommended...The stud is there to support the weight of the compressor (un-clamped) to the bracket to ensure net-locating of the compressor pully to the crankshaft pulley (belt alighnment) during torqueing of the bolts. A quick search of the interwbs shows the stud is available for purchase...see below.
Note the Torque Procedure/ Specs are for a 1999 Corvette as an example below, as you have a 2002, you will need to find your applicable specs...
Cheers,
Goose
Cheers,
Goose
