Drivers Side HID low beam not working. Can someone help me troubleshoot?
I bought a 2004 Z06 with an HID kit installed. The drivers side low beam went out. Is there a bulb inside the projector that I can replace? The high beam comes on when the brights are engaged. Keep in mind they have worked for months previously, since I’ve had the car.
I searched the board and didn’t see anything specific. Thanks I’m advance.
If the fuse is good, the ballast plugs into the OE headlight connector. Disconnect the ballast, and check for 12V there with the lights on. If you have 12V it is either the ballast or the bulb and you can switch bulbs side to side to verify.
First check the fuse for that headlight.
Ed Ramberger (11-22-2020)
