Wave form
Moderator, Tech Contributor
Received 2,136 Likes
A Tech 2 does NOT show a CMP waveform...you need a DSO (digital storage oscilloscope)...is this what you’re using ???....this is a cam-crank correlation waveform on my scope on my ‘01...bottom blue waveform is crank and top red is CMP.
[QUOTE=C5 Diag;1602039703]A Tech 2 does NOT show a CMP waveform...you need a DSO (digital storage oscilloscope)...is this what you’re using ???...
This is my attempt to gragh the cmp and rpm with the TECH 2. Thanks for the info and the graph.
You will only see a true CMP waveform
using a DSO...you want to be looking at a voltage over time waveform...this is not the true waveform one would use to diagnose a faulty sensor.
Ronnie_W (08-20-2020)
