Abs & traction control
On my 99 FRC last week the ABS and Traction Control symbols came on along with messages to check both. The car was running running well - no problems. When I stopped, ran errands, and restarted the car - everything was normal. Today the same sequence happened. Could this be a glitch, or a forerunner of major problems? I haven’t pulled codes. In the past I have had quirky little things like this come and go with different systems. The car has 93k and is well maintained.
Any quick thoughts/suggestions?
Moderator, Tech Contributor
Received 2,135 Likes
WOW !!...there has been a rash of these ABS/TC the last few days here....retrieve the codes and post them. !!
? - can high temperatures and high humidity play havoc with the our Vette’s electrical system? The temperature has been consistently over 90 and the humidity 80+%.
Until you pull the DTC's there can be no answers, the codes will tell you where to look. If you do not know how to pull the codes on a C5 Corvette, there are hundreds of videos on youtube to show you how. Regarding heat and humidity, Corvettes run very well in Miami, New Orleans, and St. Louis with much higher temps/humidity than what you are experiencing.
