How to BLEED a C5 Clutch - VIDEO
Received 1,252 Likes
St. Jude Donor '21
As you may know, the C5 clutch setup is fairly unique. Prior to the first time I bled my C5 Clutch a couple years ago, I researched EVERYTHING I could find on how best to do it.
Here is a video to share what I learned. *Remote Bleeder *Bleed stock setup from below *Bleed stock setup from above *Limitation of the "Ranger Method"
If you have more thoughts on this matter, please feel free to comment!
Toys
Toys
The following 3 users liked this post by Toys4Life C5:
Check valve or not, it's always best to run a flex line from the bleed outlet into a cup of fresh fluid, with the end of the tube kept submerged in the fluid. Just ensures any backflow that occurs won't be air.
The following 2 users liked this post by redzg:
JWM (04-15-2020),
shadyscott69 (04-11-2020)
Received 19,455 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
Received 8,961 Likes
Bill
Mine looks like this:
Maybe other remote bleeder lines are different but I wasn't able to get this to work. I could get another bleeder screw and drill a hole through the center to have the tapered end/threads seal but still allow fluid to come out.
Some have fancy check valves inside but won't help. I want to drill a thru hole on a standard bleeder so it can remain tightened into the line but still be able to pull vacuum.
St. Jude Donor '21
Thanks Gents!!
The tape appears to be the missing link that together with the previous suggestion would make this a 1 man operation. That having been said, I will probably grab one of my kids anyway to help cause it is an excuse to get them out of the house and into the shop
I found a standard bleeder screw in my "stash" that fits my remote bleeder line and I already drilled a thru hole. This weekend I'll try the one man vacuum bleeding method.
Keep in mind this only becomes a "one man job" after you pay someone to install the remote bleeder which can be costly, or done when doing a clutch job. A remote bleeder CAN be installed without removing the TT or lowering it (I know because I did it) but I was loaned a custom made tool to get the job done.
Fluid does not "flow" in the clutch system. So once it's dirty down by the slave it stays there until it backs up into the MC and reservoir.
If you plan to keep your car for a long time, it's worth it to have someone install a remote bleeder for future proper maintenance.
St. Jude Donor '21
For me, luckily I needed to upgrade to a twin disk clutch anyway so it was a no brainer to add the speed bleeder at the same time.
St. Jude Donor '21
One other thing I should have pointed out. If you get a weird squeaking sound after a bleed - especially if you go to Dot 4, it is common and should go away within a day or so. Freaked me out the first time it happened to me....
The tool was custom made by someone who makes a living working on C5's. So the tool/procedure is not mine to give out .
