How to remove the cluster
Not breaking news , but I made a "little how to remove cluster " document in approx . 15-20 minutes .
It's always a good advice to disconnect the battery before doing this and I hope someone can make use of this info
The following 4 users liked this post by oelarse:
I appreciate you putting this together. Ive been wondering how it was done.
When you were replacing the backlights, did you happen to notice if the individual gauges (oil, water) could be removed from the cluster separately?
I definitely agree with taking the few extra minutes and removing the bolts to the steering column to allow for more room. I took my cluster out and stubbornly decided to do it without dropping the steering column. Man that was frustrating . I'll definitely be dropping the column before putting it back in
