Fixed my seat!
Fixed my seat!
C3 is the black connector on the top of the SCM
Position A is on the bottom right of the connector
Closer shot
Scrounging pins
Priceless pin
My problem with my 2001 vert w/ sport seats was the driver seat. At first it failed to move in any direction but the lumbar and bolsters worked and the telescopic column didn’t work. If I got out of the seat all functions worked as well as the telescopic column. Sit on the seat...NADA..back to a failure. The problem finally went solid and I got the FSM and looked at the seat schematics. To probe the Seat Control Module I had to get access to it and when I did get it free I saw on orange wire at a weird angle to the black plug. Broken wire...Gotcha!
The broken wire was on the POS A of the SCM connector C3 which is circuit 1840, battery fused feed. Looking at the connector, POS A is on the right bottom. Getting a replacement pin isn’t an option where I live so I went scrounging and came up with a pigtail from my 74 Dodge truck side marker light and cut it open for the pin. A beer later it was spliced and soldered and the seat worked! Never throw out those old connectors!
Hope this might help someone.
JimHarris4 (02-28-2020)
Good job sir!!!
Many faults are sometimes an easy fix if you just take some time & inspect all the relevant parts.
Now why does my passenger seat tip forward form the top about 3 inches under heavy braking???
