Which one is the bleeder valve?
I forgot to take pictures when I removed my brakes. Could someone advise me which hole is for the bleeder valve? Thanks!
Received 19,394 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
They're opposite side to side because the bleeder must be located at the top of the caliper when installed. The bleeder hole has a seat for the bleeder to seal against at the bottom of the threads and should be smaller than the brake hose bolt.
You can easily use google to look up pictures.
