Differential Swap how to
Anyone have a how to on a differential swap. Thinking about taking this job on, just trying to figure out of it will be to much for me. And I would be doing it on jackstands so any input would really help me make this choice.
For what it’s worth, I pulled tranny with rear diff attached, then pulled torque tube, replaced slave cylinder, added a remote bleeder, installed a tick adjustable clutch master. Did this all in my garage with car on jack stands sitting on about (4) 2”x10” to give me some extra height. Was it a real fun job? No it wasn’t,but I didn’t have the cash to pay someone to do it for me. Plus doing it myself, I knew exactly what was done and how it was done. To swap out rear diffs I’ve heard it’s easier to pull the trans with the rear diff attached, swap diffs over then re-install tranny, with diff attached along with rear cross member. I used a tranny jack from harbor freight that worked out great. If your mechanically inclined this is not a hard job to do. Just takes some time wrenching on it. Good luck with it. If I can do it I’m sure you can too.
My tranny seals all need replacement and I am in the same boat. Dont want to spend the money to have it done so I am thinking of trying it myself. It just seams a bit daunting.
