strange belt problem
01' auto coupe. so today had to have it towed home, both drive belts off. They just came off, how the hell does that happen? I checked all pullys, they all seem good condition, turn freely, tensioners move freely. Now, I see something strange behind the crank pully there is a piece of rubber like material sticking out, it turns with the crank pully when the engine is jogged. I can't imagine what that might be and if it has something to do with the bely=ts coming off. I that pully also a balancer, could it have a rubber like material on the backside? Please any help would be appreciated. Looks like a big job to remove that pully
Harmonic balancer is shot and wobbling . Replace it. Not easy to replace but doable. Find a good mechanic. My replacement was $700.00 which included balancer, front seal, new bolt and labor.
Received 19,414 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
Hi, I am also considering changing the harmonic balancer. I found a DORMAN on ebay for $ 87.80. Does anyone have experience with it?
Harmonic Balancer Crank Pulley (5.7L 350 LS1 LS6) for 97-04 Chevy Corvette | eBay
Received 1,229 Likes
St. Jude Donor '11
PowerBond PB1117N PowerBond premium OEM harmonic balancer...
DalecarliaEric (08-26-2021)
Hi, Thanks for the tip. Just a little thought. Rock Autos GM Original Equipment Engine Harmonic Balancer Center Bore Diameter is 1.50 in. All Daycos HB Bore is 1,481 in. I guess it should work anyway.
Do you have any pics of the balancer or rubber that is hanging out? Mine is pretty old as well you can see cracks in the rubber. I noticed a belt noise that sounded like from the alternator pulley marble wobble but may be balancer like yours. I may remove the belt and see if it makes the noise id hate to end up like you stranded with the main drive belt off the car will overheat real quick. May i ask what you mean by engine jogged?
grinder11 (08-28-2021)
