Squeak up front
Squeak up front
I have a squeak that sounds like its coming from the right front. I only notice it when going slow over rough roads or bumps. Any ideas what it could be from? My Corvette is a 2000 c5.
Thank you
Thank you
Received 19,364 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
joelcastro (08-16-2019)
1/4 mile/AutoX
lube the hood stops, as mentioned sway bar bushings or end links ???
What do you recommend I lube them with? The person I purchased the car from had the stabilizer links/bushings replaced and also the front swayer links and sway bar bushings replaced already on 11/02/18. I don't know what else to do!!
Joel
Joel
I had the same squeak and mine was the shock, especially when the car was hot and temps outside were hot too. A new set of B6 Bilstein's fixed my problem.
