Valve springs
Old 05-21-2019, 08:20 AM
james02Z
james02Z's Avatar
Default Valve springs
I know there's a billion post,read almost all,going to replace springs,my 02 z06 has 39k,,,,,better safe than sorry,,,leaning towards pac 1218,,,,then I see pac 1904 kit,dual springs with seals,retainers,keepers for about same price,,,any input on the 1904 spring would be appreciated,,,,,thanks
Old 05-21-2019, 08:22 AM
vettenuts
vettenuts's Avatar
If you are stock, my first choice would be the GM springs and second the PAC. I wouldn't go to duals as you can keep your original seat/seal design valve seals.
The following 2 users liked this post by vettenuts:
ArmchairArchitect (05-21-2019), james02Z (05-21-2019)
Old 05-21-2019, 08:27 AM
james02Z
james02Z's Avatar
Default Thanks
I have cai and borla,otherwise stock,so if I go with either of your suggestions I can just replace spring using original seal ,retainer. etc........
Old 05-21-2019, 08:50 AM
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,261 Likes on 1,056 Posts
yes you can reuse everything as long as you use a beehive spring... pac are great springs but duals are overkill with stock cam/valvetrain
The following 2 users liked this post by neutron82:
Old 05-21-2019, 09:03 AM
james02Z
james02Z's Avatar
Thanks,,,should have done this years ago,,,,when I was young and confident!!!!!!!
Old 05-21-2019, 09:27 PM
Time for a C-5
Time for a C-5's Avatar
PAC makes a nice spring. If you're looking at the 1218 check the 1218x; the x means it's shot peened for longevity (depending on how much you drive it). The GM blue springs are also plenty adequate for a stock cam/push rods/etc.
Old 05-21-2019, 11:02 PM
james02Z
james02Z's Avatar
Thanks for the info,,,,,39k miles over 18 years probably get away with 1218😂
Old 05-22-2019, 04:25 AM
Spaggs
Spaggs's Avatar
I have an 03 Z with the same miles. I went with the GM Blue Springs and Trunion Upgrade. I have pretty much the same mods and track the car a few times a year at Road Atlanta. Just my 2 cents.
Good luck.
Spaggs
The following 2 users liked this post by Spaggs:
ArmchairArchitect (05-22-2019), james02Z (05-22-2019)
Old 05-22-2019, 06:56 AM
Time for a C-5
For sure. I overkilled mine with the PAC 1219x springs (mild cam) for the couple thousand miles a year I drive it.
Old 05-22-2019, 09:25 AM
SaberD
SaberD's Avatar
I would definitely go with the PAC 1218's.. These springs are well proven in racing. I got the 1215's for my ls1 when I did the rocker trunnion upgrade (which is something you should consider if you're in there already).
To Valve springs
Quick Reply: Valve springs
