Do I have this routed correctly
I just installed a catch can and would greatly appreciate if someone could confirm I routed the hoses properly. I know this is simple, but I don't want to screw anything up. Better safe than sorry. I pulled the line running from the PCV valve to the intake loose at the intake. I routed the line to the inlet side of the catch can. Then ran a line from the outlet side of the catch can to the intake where the hose from the PCV plugged in. Is this correct? I've seen some videos where the outlet hose from the catch can was routed into the valve cover.
Thanks for your replies.
That is exactly how my Elite Can is hooked up.
https://www.corvetteforum.com/forums...-cleaning.html
Clean side oil separator is probably not necessary unless your car is turbocharged, supercharged, has excessive blowby, or spends a lot of time at WOT (like, on a race track).
Supporting Vendor
need to know what make and model catch can before anyone can say for sure how it should be connected
Supporting Vendor
if it is a sealed two port can then one side would go to the intake manifold, and the other would go to a line hooked to the stock pcv exit
It isn’t sealed. The cup unscrews so you can empty it. But there is only an inlet and an outlet. That’s the way I have it hooked up. The PCV is going to the inlet and The outlet is going to the intake. It is just a cheap Chinese deal off of Amazon. It is called evil engineering. It does say it’s baffled if that matters.
