Trans-Go for A4's - What does the jury say?
Hey, y'all! been a while since I've visited. Glad to see you're all well and gabbing away.
Who's got the Trans-Go kit installed? What are your impressions? What are the pros and cons? The kits cost approx $130, but how much for install? How does the Trans-Go rate on a "live-a-bility" scale? My vert is a daily driver.
I had a Mustang owner tell me that they radically shorten the life of the tranny. But then again, consider the source - a Mustang owner. But then again, will the Trans-Go void an extended warranty?
I hate it when the damn transmission drops into 4th gear, when I LEAST want it to, but at the same time, I'm not sure that driving around in "3" all the time is a good idea, either.
Comments, help, wisdom? (Puh-Lease don't tell me to get an M6!!! I've got what I've got, want to make the most of it.) Also, I'm not ignoring your replies - but i won't be able to check back until Saturday. Thanks!
-DenMan
-DenMan
Re: Trans-Go for A4's - What does the jury say? (DenMan)
The kit will not change shift points. What it will do is make shifts quicker, particularly the 1-2 shift. TransGo claims that it will lengthen the life of tranny due to less slippage and ware.
Prgramming will change shift points and firmness (line pressure).
I say go for it. i loved mine.
1 Post
Re: Trans-Go for A4's - What does the jury say? (batsallover)
Vince Stella, Untouchable 00, and BuckMaster swear by it and love it!
The key in my opinion is to know or have a place that KNOWS how to install it. The part is cheap, the install is $150-200, but the key is having some do it that knows how to do it and has experience with it.
Now that I am keeping my car and adding 3.42's/SY3500/TR Cam/ASP pulley/ etc. I will consider it after I get everything installed and drive it awhile.
I know of no one in Dallas that has it and no one that is an expert at installing so that would be the reason I wouldn't get it installed.
Good luck.
The Bandit.................
Good luck.
Re: Trans-Go for A4's - What does the jury say? (2001 Red Coupe Bandit)
I don't know if The Vette Doctors used Trans Go or another brand but in combination with my other mods, I am very satisfied with the firmness and the shiftpoints for a daily driver and a 1/4 mile car all rolled up into one! :cheers: I also made sure to change the tranny fluid a few times to Redline Synthetic for maximum protection.
1 Post
The Transgo shift kit is the best bang for the buck A4 mod ...PERIOD! There is no PCM program that can duplicate the results from a Transgo shift kit.The best advice I can give you is find a competant experienced transmission technician and just DO IT!:smash:..It makes ALL the difference:D
More information here on this link..:Dhttp://www.txchange.com/transgo.htm
[Modified by vstella, 10:40 PM 11/1/2002]
Cruise-In II & IV Veteran
CI VI Drag Champ!
I don't have one but will likely get it when/if the my tranny gets redone.
I had shift presure adjustements done with LS1 edit. Not he same them but my car shift flawlessly.
