Trunion Upgrade-VS- Roller Rockers
Hi all,
I habe been planning my top end build and reasearching like crazy on the many options. I am trying to decide if I should just upgrade the trunions on my factory rockers or go with Comp Cams Gold 1.72 rollers. Money is not the deciding factor. I also know a lot of people have thier favorite brand of rockers and I have decied on the Comps as I have always had great luck with their products.
So, upgrade or replace?
I had the same situation last year.. All my oem stuff was perfect, but im OCD and wanted to replace my springs and rockers for peace of mind.
I decided to go with a full roller rocker.. I did the Yella Terra brand. In my research it was the only one that cleared the valve covers..
Now having said that, I DID have to buy their thicker valve cover gasket to get the clearance.. But I think it's because I used the 1.8 Rockers..
All the other brands said that they would NOT clear factory valve covers..
Straubs? Or Brian Tooley? I read nothing but good reviews for both. I haven't changed mine -- and probably won't unless I go with more cam than the Z06 I have sitting in a box -- but I have experience with other low rotation needle bearings. I've seen that needle bearings that make full rotations bear loads well, and don't show wear for a long period of time. Needles that only rotate partially, and then reciprocate in that short rotation tend to wear detents into the races. Stock valve covers would matter to me as well.
Received 1,261 Likes
straub or che, if they look anything like comp I would stay away personally
According to both Brian Tooley and Kurt Urban the max lift on a 15* head with stock rockers is .630. But don't take my word for it... straight from Mr. Tooley himself....
I installed Summit Racings trunnion kit along with my Texas Speed 224 R cam (.600 lift) about 4,000 miles ago , Engine had at least six HARD pulls on the Dyno & I've run it up to stock redline quite a few times , I have the Engine apart right now to install PRC heads , visual /physical inspection of rocker trunions shows no signs of wear , they still look new ! I also didn't hear any more "sewing machine noises" than before and this was with stock 130,000 mile lifters with a .600 lift cam . Summit offers a complete package to upgrade the entire valve train , would have bought that if I'd known at the time . Have fun !
Interested in your setup. I have something very similar. PRC stage 1, Torquer 2 and Fast 92. I've been thinking about upgrading to the 227's so I'll be watching for your results. When do you think it'll be done? Oh, and I have straub bushings in factory arms. No problems.
I used the 1.7 rollers and they cleared the valve covers with the stock gaskets.
https://www.youtube.com/watch?v=n9VCzYh3YKA
I hear yah.. the stock rockers are acutally really good. Kurt Urban uses them a lot of milder builds because they are so good. I too have stock rockers with a smith bros. bushing kit... but I also have a stock cam as this car is my daily driver. I may go with aftermarket shaft rockers but that would be for valvtrain stability …. and a 1:8 ratio.... the reason for this for me would be to keep the stock cam yet gain a little something with the ratio change.
