Powerbond Harmonic Balancer with no drill holes
With all the work involved in replacing the harmonic balancer, I want to be sure the part I received from Summit Racing is correct. I ordered and received the PB1117N. The only concern I have is there are no holes drilled in the facing of it like the pictures of it online. I called Summit and the customer service rep said it was fine. He even reached out to DAYCO while I held and they said the part was balanced without the need for any drilling. He said some require a number of holes and every once in a while they have some that do not require any holes.
Anyone else experience this?
Thoroughly chapped
Location: If you're not angry, you're not paying attention
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Nope, no holes. I just pulled one off the shelf, and checked. Also checked the Dorman version.....no holes there either.
The following 2 users liked this post by 'Shifter:
ArmchairArchitect (10-31-2018),
Cameldog (10-30-2018)
