C6 Z06 brakes installed on 2001 Z06
Old 05-10-2018, 12:10 AM
YLO Z06
YLO Z06's Avatar
2023 C5 of the Year Finalist - Modified
Default C6 Z06 brakes installed on 2001 Z06
Finally got around to installing my C6 Z06 brakes on my 2001 Z06. I bought the calipers as take-offs from a 2012 Grand Sport, picked up slightly used stock pads, and the rest of the stuff (rotors, speed bleeders, caliper powder coating, SS brake lines, Motul brake fluid) from TPI Motorsports. They were able to match Millennium Yellow using a color called "02 Vette Yellow".
Stock front brake set up
Everything came off fairly easily, with minor trouble getting the new SS brake lines on. New rotors and calipers mounted below
C6 Z06 front brakes!
Rear set up
Once I put the front wheels on, however, I was shocked at the minimal amount of clearance between the spoke and the caliper . These wheels are TSW Interlagos, 19"x9" front. Everything I read on the Forum indicated that these wheels would clear C6 Z06 brakes, so I did not worry about it until I fit the wheel on. I hand spun both front wheels and noted no rubbing, so I am going to live with it for a while and see how it does. Worse comes to worse, I will buy some small spacers for the front wheels. No clearance issues on the rear (19"x10.5").
Tight fit!
Also bought a carbon ZR1 spoiler from C7 Carbon
Got everything buttoned up and road-worthy just in time for my local car show on Sunday (I did not win, though )
The following 3 users liked this post by YLO Z06:
ElisTwoCents (05-18-2018), tdf01cycling (05-10-2018), tommie (05-11-2018)
Old 05-10-2018, 09:34 AM
mark4cam
mark4cam's Avatar
Looks fantastic, nice job on the brakes. Do you notice a firmer pedal? That's my biggest gripe with the brakes. They are strong, but the pedal has a little travel before it firms up. I came from the Porsche world where brake pedals are like rocks, would love to get that feeling back.
Man I have GOT to get rid of the side moldings on my car, looks so much better without them. Beautiful car!
Old 05-10-2018, 09:50 AM
Pounder
1/4 mile/AutoX
Support Corvetteforum!
Pounder's Avatar
Received 2,082 Likes on 1,635 Posts
Old 05-10-2018, 12:41 PM
jrp1588
jrp1588's Avatar
Looks great. Wish my wheels would fit them.
Old 05-10-2018, 02:35 PM
fivelitrecobra
fivelitrecobra's Avatar
2018 C5 of Year Finalist
Looks fantastic, Really fills up those wheels! How much of a difference in weight was there between the C5Z rotors and the C6 rotors?
Old 05-10-2018, 09:11 PM
neutron82
neutron82's Avatar
Received 1,261 Likes on 1,056 Posts
all in all I want to say c6z brakes add about 50lbs total... you can feel the difference in mass at first but you will get used to it and if you add a significant amount of power to the car you won't notice it anymore
Old 05-11-2018, 11:54 AM
Fastbird
Pro Mechanic
Fastbird's Avatar
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
You have more clearance than my CCW SP500's have on my C6Z brakes. But if it clears, it clears. The wheel isn't going to change position, and likewise, the caliper isn't going to move either. What I'm getting at is you don't need to worry about a wheel spacer. If it clears now, it clears later.
Old 05-11-2018, 12:43 PM
JHrinsin
JHrinsin's Avatar
IIRC, Wilwood recommends a minimum clearance between the caliper and the wheel rim or spoke of something like 0.080". Somethings you have to watch with the location or even have to move the stick on weights. BTW. shape looking Z06!
Old 05-18-2018, 12:55 AM
ElisTwoCents
ElisTwoCents's Avatar
St. Jude Donor '05-'06,'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Great looking Z....pardon my ignorance, after owning a couple of other Vettes I picked up a C5Z:
Direct swap essentially, no brackets needed?
Old 05-18-2018, 01:22 AM
Fastbird
Pro Mechanic
Fastbird's Avatar
Direct swap, no brackets needed. Just need longer hoses.
The following 2 users liked this post by Fastbird:
ArmchairArchitect (05-15-2019), ElisTwoCents (05-18-2018)
Old 05-18-2018, 08:18 AM
jrp1588
jrp1588's Avatar
You'll also need larger wheels to clear them. That's what stopped me.
Old 05-18-2018, 08:40 AM
sabastian458
sabastian458's Avatar
My brake pedal after the swap was firmer, brake grip was near instant. With some modification, you can swap to a larger bore master cylinder, may help with your pedal issue.
I love the yellow, I wish I had went that color on mine. (Went darker red than the way they come) what from lip is that?
Old 05-18-2018, 08:45 AM
neutron82
neutron82's Avatar
for anyone interested, look into doug rippie's brake lines... they are made by goodridge and use -an fittings instead of banjo bolts... they cost a bit more than others but are worth it in my opinion, they are the nicest and best fitting lines I have used
Old 05-18-2018, 12:54 PM
Fastbird
Pro Mechanic
Fastbird's Avatar
These are what I went for also. I preferred the steel -an fitting over the banjo bolt. Good pieces for sure.
Old 02-14-2019, 09:05 PM
CorvetteAdvisor
CorvetteAdvisor's Avatar
Honestly factory brake lines are cheap... Just pick up a set
Old 02-17-2019, 01:08 AM
10thumper
10thumper's Avatar
How well do the yellow calipers match your yellow paint? I’ve been considering also.
Old 02-17-2019, 10:16 PM
knr13
knr13's Avatar
i love my C6 Z06 calipers
night and day difference !
To C6 Z06 brakes installed on 2001 Z06
Old 05-13-2019, 01:07 AM
YLO Z06
YLO Z06's Avatar
Originally Posted by sabastian458
...what from lip is that?
C5-R splitter in carbon fiber from Corvette Creationz.
Old 05-13-2019, 01:11 AM
YLO Z06
YLO Z06's Avatar
Matches really well, almost spot-on to Millennium Yellow. I am quite happy with the color. If fact, I am planning on having a few underhood parts powder coated in the same color . It is made by Prismatic --> https://www.prismaticpowders.com/sho...2-vette-yellow
Old 05-15-2019, 10:13 AM
jackthelad
jackthelad's Avatar
But, that's 50 lbs of unsprung weight, putting a lot more inertia into wheel movements, not a good idea unless it's really essential.
ArmchairArchitect (05-20-2019)
Quick Reply: C6 Z06 brakes installed on 2001 Z06
