DTC Codes B0-RFA U1000H and U1064H
My 2001 vert has these 2 codes that keep coming back after being cleared. Radio aux button does not get a response on radio display when trying to use the trunk mounted disc player. No other problems with the car. Does anyone have any suggestions. I have checked all grounds.
does the disc player work?? try unplugging it. clean the plug and pins and lightly apply some dielectric grease and plug back in. so far this method has worked on recurring codes on my C5. good luck.
parrottp (05-07-2018)
The RFA code is related to your Remote Function Accuator - key fob in layman's terms. The 1064 is a communication error. Try Googling both and see what you get.
Also - this section is OFF TOPIC, which means you are prohibited from discussing anything Corvette related under penalty of being ripped to shreds. No one here owns a Corvette - they're just here for the great personalities and friendship.
Next time you have a question - try C5 General or C5 Tech. Good luck No0B....
Terminal end in CD player not making contact
Wanted to let you know that the female terminal on the orange 12v power wire in the plug to the CD player was not making contact with the male on the CD player. I temporarily repaired it by removing it from the plug and squeezing it together to make contact. The plug is no longer available but the terminals are. I ordered 10 and will replace them all when the player comes back from Doctor Don's for a design upgrade. Thanks for your suggestion to look in that area for the problem. I still have the code problem. I am going to wait until after I install the updated CD player and then check to see if I still have them. Tahnks again.
