need help locating part number for rear caliper mounting bracket bolts
I've called numerous dealers and they don't know what I'm talking about so hopefully someone here can help me. I need to get replacement bolts circled in red in the following pic. I had Eradispeeds (plus sized) rotors on my c5 for a decade and decided to go back to stock, which is why i need to go back to stock bolts. The eradispeeds had a custom mounting bracket extension which also came with longer custom bolts which I can't use to go back to stock.
I think i might have found it GM PART # 14067559 REAR BRAKE CALIPER BOLT if anyone can confirm would appreciate it. The dealer says this part is discontinued though unfortunately. I'd hate to just use a random bolt bought from the part store because this bolt requires 125lb/ft torque.
vectorz (04-10-2018)
Received 1,261 Likes
14067559 is the bolt circled in blue that goes into the caliper pins... smoken1 is correct with the other part # for the mounting bolts, the one circled in red... call or email Marc at vettenuts, I bet he has a billion of those bolts laying around
vectorz (04-11-2018)
