1997/1998 fuel pressure pulse damper question
For those of you who have installed a bigger intake and Supercharger or swapped fuel rails, are you still running a line from the damper to the coupler? Can it just be capped if I install a boost-a-pump?
That is not a pulse damper, it is your fuel pressure regulator just cap it and it will maintain your FP @60psi all the time if you have enough pump. Or you can run a line to it from your intake and have it tuned that way but your tuner will not like you.......
Now I need to find out if it's worth it to change to a single fuel line system.
