Fuel Pressure Update
Ok this one has me baffled , the pump and the sending unit have been replaced and I have moved a couple of relays around . The car ran great for two days and then on day three it would not start again. Checked and once again I have no fuel pressure at the rail but if I continue to spin the engine over it gets pressure and starts and then looses pressure and dies. Cycle the key and no pressure and spinning the engine over and no pressure that way either. I used the relay for the fog lights and retried it back in the fog lights and they work fine so it' not the relay. I tried bending the tabs on the relay just a touch to make sure that they where getting a good contact in the fuse box and no change. I am not sure which pin on the relay is the main power and which is the signal pin , if I knew what each pin did I could test for power and for the signal and power to the pump. I am about ready to put a match to the damn thing and be done with it but maybe with A little luck and some help from everyone on here I can finally figure the damn thing out.
